Subject: Re: Supplied air question
9/25/21
Phil Member
Hello,
Looking to switch over from cartridges to a supplied air system. Was thinking of going with the Allegro one-worker ambient air pump (link below). Anyone have experience with this type of set up? How does it compare to one that hooks up to a compressor? Would be used in a booth . Thanks!
https://www.northerntool.com/shop/tools/product_200856864_200856864?cm_
mmc=Google-pla&utm_source=Google_PLA&utm_medium=Safety%20%3E%20Respirator
y%20Protection&utm_campaign=Allegro&utm_content=106065&gclid=Cj0KCQjw
kbuKBhDRARIsAALysV4-5r2E1LqvfwIGXCmHXU82f6zt3j87TOwgphZRgrEcclMAOle3Yu8aAjO-EALw_
wcB&gclsrc=aw.ds
9/25/21       #2: Supplied air question ...
CraigM
I have one. The pumps are great but the hoses and masks are junk. I use an Allegro 3/4HP pump with 3M hoses and Versaflo mask. If you're going to use a full face mask or hood you need the 3/4HP pump, not the 1/4HP. If you use an ambient pump you won't be able to the vortex fittings that heat or cool the air coming to the mask.
9/27/21       #3: Supplied air question ...
I use one similar to this turbine pump. It appears that the company I bought from is no longer in business, so can't vouch for this exact one.
9/28/21       #4: Supplied air question ...
Al
I asked similar questions a couple years ago. Craig responded to my questions just as he did yours. I took Craig’s advice and got what he recommended. After wearing it for about 30 seconds my only regret was not getting this a long time ago.
9/28/21       #5: Supplied air question ...
chris
i use a 3M versaflow unit hooked up to a compressor.
the only issue i have is that if i turn down the unit to cold air then the mask will fog up.otherwise the hood is very comfortable. definitely recommend
10/4/21       #6: Supplied air question ...
Phil Member
Thanks for the responses!
