Subject: Re: Chemcraft
Chemcraft
11/13/21
FM
So WLC has dropped MLC from their finishing products and replaced them with Chemcraft. I’ll skip my frustrated rant about time lost in learning curves and inventory-okay almost skip it- what can you tell me about Chemcraft. The solvent side of the business. Stains, clear CVS, pigmented CVs. What are the pros the cons, anything technical that will put me ahead of the learning curve? Much appreciated upfront! Thank you
11/14/21       #2: Chemcraft ...
Tom Gafgen
I've been using chemcraft products for nearly 15 years . I spray with a Kremlin 10/14 and get flawless results every time.,whether it's the middle of a humid summer or in the middle of a cold Winter (I'm in New Jersey) I spray the clear C v's right out of the can with no reduction and the pigmented C v's I spray 2 Coats of primer both reduced 15% and one top coat reduced 10% Be sure to use the camcraft reducer. I spray 20 sheen for everything.
Their wiping stains work really well also, And I've often added 3 to 5% stain to my clear sealer to darken things up a bit with no problems.
11/14/21       #3: Chemcraft ...
FM
Thanks Tom. Can you give specific names of the products you are using, including the reducer and stain? Thank you again
11/23/21       #4: Chemcraft ...
Pdub Member
I think the bigger message is to get away from WLC, not MLC. I have a feeling I know what area you're in. MLC has other dealers their now. WLC has terrible service and high prices. In the CO area, they had the option to continue to offer the MLC to their clients for quite some time to ease the transition, but they opted to drop immediately and offer all of their clients only what they had in stock. Lots of people are high and dry with their custom colors now.
