Subject: Re: CV Questions
CV Questions
11/16/21
Andrew Member
I am new to conversion varnishes and thought maybe someone could help me on this. I've got a project for a customer now that I'm building custom cabinets for; some of them are black, some are white. These will be my first painted cabinets and I want to make sure moving forward I am using the best quality finishes and get the correct equipment the first time. My building has my space limited so I would like to get into waterborne CV finishes. What manufacturer do you guys recommend for this? At the IWFS show this year I talked to most of the companies there including Gemini which I liked, but their product is too hard to come by locally.
Thanks,
Andrew
11/16/21       #2: CV Questions ...
Painting anything black requires impeccable preparation. Do many complete samples before even thinking about the job. No way can you estimate the first job correctly without knowing what it really takes for quality. If you're doing raised panels, pre paint the bevels before assembly. Nothing looks worse than shrunken panels showing raw wood or primer. Speaking of primer, that's super critical too. One coat will not be enough. Tint that too, be prepared to find out how your preparation procedure worked out. I prefer a clear coat over the color. It lets you take out the last nibs and and flatten the finish, then add the clear. A quality booth is important. You don't want a single chance of getting dust around the wet coats. Sorry I can't recommend a water based finish. If your shop does some higher volume, talk to regional reps and ask for samples.
