Subject: Re: white ring on conversion varnish table top
12/1/21
Tim Kieronski
Website: http://Woodaccents.com
Tabletop has a white ring that looks like a water stain. The ring was caused by a mug out of the microwave set on a cloth placemat.
The top has a pommele sapele field and wenge sol;id edges. Finish is conversion varnish, satin.
Does anyone know if there is quick fix for this? If not I guess it will have to be resprayed.
12/1/21       #2: white ring on conversion varnish ta ...
Be patient. The ring may disappear in a day or two as the water driven into the finish evaporates. You can try hitting it with a hair dryer for a few minutes to speed up the process.
12/2/21       #3: white ring on conversion varnish ta ...
Could be a chemical reaction for the hot vinyl, but I've never seen it happen. Do you thin your conversion varnish a lot? Satin has a lot of flattening agent in it, that might be part of the issue. Just thinking out loud.
12/9/21       #4: white ring on conversion varnish ta ...
Daniel Shafner Member
Conversion coatings, or any coating which isn't a purely evaporative coating, do not re-solvate, meaning, they don't go back into solution. They either resist any solvent or they wrinkle.
That means that your mark in the finish can't be removed by trying to lightly rag the surface with ethanol, or to lightly spray the surface with retarder, or with some similar acting re-wetting type solvent.
If the mark is from water, and the coating is a conversion coating or a waterbase, that's no hydrophilic chemical that's going to solvate to coating so that the moisture can release.
If the mark is caused by a reaction with vinyl or rubber or foam, as RichC suggests is a possibility, then evaporative coating or not, the film of the coating is disturbed and the best fix is refinishing, removing the damaged film, first. Almost always, whatever you last down on top of a coating that's suffered the effects of plasticizer migration, won't stop the damaged film from telegraphing into your new topcoat.
12/10/21       #5: white ring on conversion varnish ta ...
nicko
I saw a video once of a guy that put some lighter fluid on a white water mark ring and then light it. I think it took him a time or two but it came out. Might find that video on youtube
