Subject: Re: waterborne 2k poly
waterborne 2k poly
12/9/21
Kevin Jenness Member
I recently had a contractor ask me for a recommendation for a "bomber" finish for a wood slab countertop to be finished in place (not what I would have suggested, but anyway...) I suggested that he look into brushable 2k poly finishes but could not give him any definite guidance.
What is the state of the art in this category? I know Milesi makes a waterborne 2k poly which is available in my area through Atlantic Plywood. Has anyone used this or similar products? How do they compare to solvent based? What is the ppr required with the catalyzed product? What other finish types would give a similar quality result for a residential kitchen countertop (that has to be finished in place)?
12/9/21       #2: waterborne 2k poly ...
Mark B
I ran MLC Aguatana 2K for a long while. Was very impressed (amazingly impressed) with the product and finish other than price. $130+ a gallon catalyzed was a bitter pill. The build was amazing and you could drop a part on concrete barely see the defect. Local distributor did nearly zero water so had to bring in full cases of catalyst which sucked. Bringing in 30 gallons worth of catalyst to spray 10 gallons of material didnt play out.
12/10/21       #3: waterborne 2k poly ...
My experience with the MLC wb 2k is the same as Marks. Absolutely bombproof. The clarity is excellent. I once sprayed 6 coats of finish in one day on a quatersawn oak desktop. I waited 1 day and buffed it with the random orbit. That stuff cures very hard very fast.
12/13/21       #4: waterborne 2k poly ...
Mark B
Kevin,
Missed the PPS part. The MLC 2K does have the isocyanate issue but where you specified brushing, skin contact and a mask would seem more than sufficient as full protection for spraying. I wear gloves and a respirator while catalyzing but then of course spray is full setup. I'd have no issue personally if I had to brush it with gloves and a half mask.
12/14/21       #6: waterborne 2k poly ...
DannyB Member
Milesi's waterborne 2k poly is awesome as well (and available in both sprayable and brush/roll formulas)
If you want to avoid iso, the best one i'm aware of is mohawk's new aristothane. It is solvent based.
This is a new generation of iso-free catalysts for polyurethanes.
They are the first i'm aware of on the woodworking side to have used this chemistry.
(They are based, AFAIK, on a Dow innovation. https://www.paint.org/coatingstech-magazine/articles/isocyanate-free-polyurethane-
technology-wood-coating-applications/ has a good intro.
