Subject: Re: Kremlin 15:1 for WB vs my Greco 9.5 HVLP
12/18/21
Mike m
Hey guys and gals.
I have typically only used solvent based paints, but I have a job coming up where I’m painting 5 interior doors, with jambs, 5 bi fold doors, all the door casings and all new base throughout the entire house.
I currently have a Greco 9.5 HVLP siphon gun for WB paints
This job will entail me to spray WB ilva paint and MLC WB primer.
I already have two Kremlin, one for solvents paint and one for solvent clears.
I’m ok with buying another 15:1 Kremlin, but to only use for WB paints. Here in Chicagoland, we aren’t restricted to use WB, so I don’t want to spray clear WB
Do any of you use a 15:1 Kremlin for WB and have you sprayed ilva WB with iit?
Considering how heavy the 9.5 Greco cup is on my wrist and the amount of product I need to paint, will I have a nicer finished look using a Kremlin over the Greco HVLP? It looks nice, but not as nice as my solvent pigmented finishes do with my Kremlin.
Putting the investment part aside, I’m much more concerned about the quality of my finish than the cost of a new AAA to dedicate to WB.
If I do take the plunge, would you recommend a different tip than the one that comes with it?
Ty
12/20/21       #2: Kremlin 15:1 for WB vs my Greco 9.5 ...
Matt
You should be able to spray WB through your Kremlin using an appropriate denat alcohol pre-wash to avoid allowing your WB paint to come in contact with lacquer thinner/harsh solvents in your pump. Flush out all the "wash thinner" with alcohol, then flush with water.
I've done this a number of times on my 14:1 CAT pumps including spraying SW Duration exterior paint.
I'm not familiar with Ilva paint, If it's the thicker "wall paint" that's normally rolled on or sprayed with an electric pump, you're going to need to cut it with water and use a fire-hose sized spray tip, and even at that you'll need to experiment.
If you're only spraying 5 doors and such, I wouldn't go buy a dedicated 15:1 for spraying WB. Contact your Kremlin rep and ask their advice on tip size, and ask their opinion on doing alchol/water changeovers in your current pumps.
If you were spraying 500 doors, then yes, buy another pump. And if this is a thick wall-paint type, buy an electric pump.
12/20/21       #3: Kremlin 15:1 for WB vs my Greco 9.5 ...
Mike m
Matt,
Ty for the suggestions. I has this discussion with my finishes rep and it wss not advisable to do the changeover. Being a single guy with no kids, I have the means to buy a dedicated pump, so I’m not concerned about the cost.
I’m more concerned about the weight on my wrist of using my Greco 9.5.
It’s not just 5 int doors, it’s 5 or so bi folds, several hundred feet of bsse, all the casing as well.
I just went by to know if the end result lock is going to look anywhere near as good as what I get for my solvent-based Finishes. Ilva and Melisi are sister companies and their WB paints are much more durable than SW,etc
12/20/21       #4: Kremlin 15:1 for WB vs my Greco 9.5 ...
Mike m
Matt,
12/21/21       #5: Kremlin 15:1 for WB vs my Greco 9.5 ...
If you have the money, go out and buy an electric airless pump like mentioned, if you have no intention of doing a lot of water base you can buy a smaller entry level or mid level machine.
In my opinion a 15:1 aaa pump is a little small for spraying most of the thicker water base coatings. It can be done, but it is like hauling all your cabinets and doors to the job site in the back of your car. Not very efficient.
12/22/21       #6: Kremlin 15:1 for WB vs my Greco 9.5 ...
Mastercabman
I'll give you my opinion
If this is a job that comes around once in a while then I would just use that Graco sprayer that you have if the coating you are using is thin enough
I've had my share with turbine sprayers and never liked them
For one,I hate that heavy big cup at the bottom
Second,too slow!and blows too much hot air
If you are interested in getting an additional pump just for WB I guess a Kremlin would be fine
I just added an Graco Merkur 15-1 pump to spray WB like BM Advance when needed
It does a good job
I keep my CAT pump for solvent finish
I don't like converting my pump from solvent to WB
I'm always worrying about contamination so I don't do it
Whatever you decide,good luck with it!
