Subject: Re: Butyl cellosolve
Butyl cellosolve
1/28/22
Dave
Hi. I have been spraying Chemcraft Aquaset/Aquaprime and some of the paint has cured in the end of the fluid tip of my gun causing fluid to bleed out. The SDS sheet for this product says use Butyl Cellosolve to remove hardened material. Not sure what BC is or where to source. (and the internet says its pretty nasty). Is there another solvent that would work? Lacquer thinner didn't seem to have much effect. Any suggestions?
Thanks.
1/28/22       #2: Butyl cellosolve ...
Matt Calnen
I get mine at Sherwin Williams. I would personally not consider it anywhere near as hot or “nasty” as lacquer thinner.
1/28/22       #3: Butyl cellosolve ...
Dave
Thanks Matt.
1/28/22       #4: Butyl cellosolve ...
shenendoah
have you asked chemcraft???? Last I knew they sell it in gallon cans for mucho dinero ( as do everyone else ). Butyl cellosolve has numerous advantages as an additive, primarily to be used as a very slow flow enhancer to keep your coat open for less orange peel i.e. better "flow out", and by happenstance to keep your tips less clogged by finish build up.
To waterborne start at around 1% and go from there.
Or, if you are satisfied with your flow out, how about keeping a cup of acetone with a brush in it to occasionally keep your tip clear/clean?
1/28/22       #5: Butyl cellosolve ...
I use an ultrasonic cleaner with GL10 stripper (30%) to clean tips if they get clogged up.
1/29/22       #7: Butyl cellosolve ...
Alcohol & acetone are very aggressive on waterborne.
I typically give a gun a good final clean with denatured.
At this stage, I would soak it in acetone rather than wasting your money on Butyl Cellsolve.
Simple green is an excellent cleanup/brush/gun cleaner for wb. Why? It’s got butyl cellsolve in it. Be careful cleaning guns. It etches aluminum.
