Subject: Re: air bubbles on slab table
2/10/22
Larry Member
I am actually finished with this project except for a couple of stools, but after pouring my slab with clear epoxy, I am experiencing a lot of air bubbles. They come immediately back after I torch them.. All knot holes and cracks were sealed with a fast drying dyed epoxy prior to this. everything was also finish sanded with 220...
It seems that the epoxy is penetrating into the pores in the wood and causing the bubbles. Is there a sealer or something I could use to stop this? This is my first project of this kind so I really am learning by trial and error.
Thanks for your help
2/11/22       #3: air bubbles on slab table ...
Thomas M Diel  Member
Website: http://thomasdiel.com
I always have this problem, argh! I first drill them out w/ a #2 double end drill point countersinks (metal lathe / mill bit) which creates a dome for second coat & fill again w epoxy... Then fill the stubborn ones with Mohawk wax sticks and roll on ICA 2K sealer. No short way around it though, I would like to find a better less time consuming method.
Bueller, Bueller, anyone,
TD
2/11/22       #4: air bubbles on slab table ...
Chemmy  Member
???.....Did you blow out all the pores to make sure they were empty of fine sawdust accumulation? Compacted sawdust can trap air within it especially on open grain woods.! If the answer is, yes you did, then the best way to insure no air bubbles forming from the pores is to seal them with your quick dry epoxy with all the excess scraped off before drying, doing controllable small areas at a time, say a couple sq. Ft....
You can use a slower drying epoxy or even a polyester to do this also, once dry, remove and and all surface coating by sanding, and you will then be able to pour without anymore problems.!!
2/11/22       #5: air bubbles on slab table ...
What brand of quick dry epoxy do you use? The stuff I have tried in the past isn't very clear and will work if tinted but is more cloudy than I prefer.
I do blow out, but yeah the live edge oak slabs and some walnuts are the major PIA.
2/11/22       #6: air bubbles on slab table ...
I did blow it out to get rid of sawdust. Then I wiped the board. It is white oak so I guess they don’t cooperate much. The fast drying epoxy I tinted black. It is from West Systems I believe. I used to to fill cracks etc. I didn’t coat the whole slab though. I’ll try spreading a thin coat to the whole slab, work it in and then sand. Thank you all for your advice!!
2/26/22       #8: air bubbles on slab table ...
Hakam G
SEAL the wood first before you pour epoxy, air bubbles are coming out from the slab itself (open grain ) it will not be prevented unless you seal the wood
