Subject: Re: Achieving dry film build with dark opaques
2/11/22
M
I use exclusively MLC products. Whenever I need to paint with whites or off whites, I'm not having any issues with achieving desired dry film build given the schedule I have been using.
(Prime, sand, color, scuff, color.)
My issue comes in anytime MLC mixes up a color for me where a white base can't be used. So, instead, they use a krystal clear base and tint the hell out of it to achieve the color I want. In these cases I use black clawlock as the primer and follow the same schedule as above. But obviously using black clawlock (which seems much thinner than its white counterpart) and a tinted clear leaves me with a much smaller dry film build.
Aside from just adding an additional scuff and color step for these darker colors, are there any products or methods anyone is using to achieve a similar dry film build to white based colors and clear based?
Just trying to prevent the need for that additional step. I'm assuming there isn't anything out there and I just need to do this additional step. Figured I'd at least throw this out there to see if there is some "magical" product or technique I'm oblivious to.
Thanks in advance.
2/12/22       #2: Achieving dry film build with dark ...
Daniel Shafner  Member
The clear base is always a thinner product vs its white base sister.
But why Krystal as a base and not Turino clear base?
An alternative to black Clawlock is to take Level Sealer and mix in 5% of your own IC black colorant. It's so much easier to sand than Clawlock.
