Subject: Re: precat primer under post cat
3/3/22
TRAVIS D ALFREY
I have always used precat mlc products and think I want to try some post cat finishes. I was wondering if I can use the same precat primer under the post cat tops or must I do post cat for all coats.
3/3/22       #2: precat primer under post cat ...
Mastercabman
You can use white vinyl primer but they suggest to catalize it with 1%
Some people will tell you that you don't need to but I always did
3/3/22       #3: precat primer under post cat ...
Never a good idea to put a harder finish over a softer finish. I would use a post cat primer along with your post cat finish. Stay within the system you choose, so don't mix products.
3/4/22       #4: precat primer under post cat ...
Mastercabman
I should of said what Leo advised
Stay with the system
Never put a hard finish on top of a softer one
But again as I said WVP can be used if catalyzed
