Subject: Re: Optimizing your materials
4/25/22
I was wondering what you are doing to optimize your material use with the finishes that have a short pot life. Also has anyone come up with a good container for your pick up tube to sit in on your air assist and your airless sprayers?
I find when you are doing smaller jobs, it is difficult to optimize the use of coatings, I like to use my Kremlin air assist pump. you mix up a litre or quart of material and you have to try get most of it in the pump and then the pot life is short so you need to try use as much as you can before it goes bad.
Thanks for any help.
