Subject: Re: Ml campbell post cat
4/29/22
Travis Alfrey
I am finally ready to make the switch from precat to post cat after 20 years. Which Ml Campbell post cat products do you like for kitchens? Clears and pigments. I use kremlin aaa set ups as well as some pot guns from time to time. Also any must purchase items other than the catalyst and mixing cups for the post cat stuff. Thanks
Maybe an old dog can learn new tricks.
4/29/22       #2: Ml campbell post cat ...
Mastercabman
Travis
I use MLC
They came out with a new post cat CV over a year ago call Turino
I've been using it for about a year now and really like it
It does have a 24 hours pot life and it is low odor
You just need the care catalyst (same ratio as usual 10/1)
I usually add 5-10% of flow enhancer
As far as clear,I still use Krystal
That stuff lays really nice!
5/3/22       #3: Ml campbell post cat ...
Brent
Same as above. Pigmented Turino over clawlock primer for colored jobs, and Krystal for clear jobs. You'll wish you switched long ago. You will need care reducer as well, and trial and error will tell you how much to reduce for the different products and different environments you will spray in. Once cured it makes for a nice hard finish.
5/10/22       #4: Ml campbell post cat ...
I personally won’t bother with CV or ML anymore. Ever since I had lap mark issues using Polarian and the manufacturers rep telling me I was the issue, vs a flattening agent problem, I switched to ilva acrylic urethane and I won’t even bother offering CV.
Ilva urethane is top notch. No more lap marks. I also only use solvent based and spray with a 15:1 Kremlin AAA.
