Subject: Re: Type of finish
Type of finish
5/9/22
Chris
I have been buying white lacquer from Sherwin Williams but they told me today that the whole district was out of theT77-W 20 and didn't know when any would be available. And to top it off they told me that they was stop tenting it you could only get white. I see right now that I am going to have to find a different finish or a new supplier. I am finishing new cabinets. What is the finish most of you all are using now?
5/10/22       #2: Type of finish ...
For pre-cat lacquer finishes, I will use solvent based Axalta and their post cat CV for the primer. I use to use ML, but I no longer like their solvent based products….for the most part
5/11/22       #3: Type of finish ...
Chris
So you use Pre cat lacquer also, What are some of the good waterborne finishes that you might use? I am not familiar with the finish you use.
5/11/22       #4: Type of finish ...
Mastercabman
I use MLC
For precat I like magna Max and magna clear
For CV I like Turino
I've also been using Lenmar brand
It's alright,a little cheaper than MLC but I think MLC is a better product
I only tried their precat as they don't stock their post cat that much
5/11/22       #5: Type of finish ...
Chris,
I don’t care for waterborne, but when I have, I only use ilva That’s a 65, but I typically use the 30 sheen, which is more of a matte
The WB primer I use is Aquafi
5/11/22       #6: Type of finish ...
Chris
If you don't mind me asking what does MLC water based finishes run a gallon. I ended up buying SW Emerald finish to do my latest job, I appreciate you guys input.
5/11/22       #7: Type of finish ...
Chris, it is a pointless adventure for any of us to tell you what we pay for the product, because that in no way means that is what you are going to pay. Plus, you have not said what water-based product you are interested in. If you want high-quality and durability, you are better off with ilva
5/11/22       #8: Type of finish ...
Chris Member
Thanks Mike I will will look into that ivla
