Subject: Re: Fresh air hood.
Fresh air hood.
6/9/22
Just wondering how many of you are using fresh air hoods? What brand are you using, or what brand do you recommend?
Pros and cons?
6/9/22       #2: Fresh air hood. ...
CraigM
I use a 3m Versaflo 200 mask with an Allegro ambient pump that brings in air from outside. I love the 3m mask, i pretty much live in it. It you use an ambient pump to a full face mask or hood you need to make sure you use at least 3/4hp pump. You can also run a mask off your compressor, but you need to run it through a filter wall. Pros: I feel much better at the end of the day vs wearing a half mask filter respirator. Cons: You need to get used to dragging a hose around. It's also a pricey up front cost.
6/10/22       #3: Fresh air hood. ...
chris
i also use the 3M versaflo hood but I have it connected to my main compressed air line.
air runs through 3 filters before I breathe it.
6/15/22       #4: Fresh air hood. ...
I believe you can run masks off of a small diaphragm(oil free) vacuum pump plumbed backwards. You don't need a hell of a lot of air pressure to breath.
6/15/22       #5: Fresh air hood. ...
Scott E Member
I also use a full face, supplied air system with an air pump. I think I got it from SAS, but there isn’t any branding on it and I bought it years ago. It’s very comfortable having fresh air blowing on your face all day. Plus it protects your eyes. You get used to the hose.
