Subject: Re: Painting wet pressure treated
6/28/22
Orin Zelenak Member
I’m installing a fence and would like to paint it but it’s wet pressure treated. I can wait for a few seasons to let it dry but would like to paint one side of the posts and then be face of the rails (for ease of installing and aesthetic purposes).
I can use exterior acrylic and believe the moisture in the wood can still easily escape the unpainted sides.
Any cautions or thoughts?
6/28/22       #2: Painting wet pressure treated ...
The paint will absolutely fail. Water behind paint will bubble and push the paint off. Water does not mix with a cured film. The caution about proper application of paint isn't a lie, or a suggestion.
6/28/22       #3: Painting wet pressure treated ...
orin zelenak Member
Thanks for taking the time to comment. Any suggestion about what an acceptable / "safe" moisture content would be to paint? If I leave these to bake in the sun for a week or two might that be enough or do I need to wait seasons? I can wait but that would be a pain...
6/28/22       #4: Painting wet pressure treated ...
JeffA
I would think that the company that made this treated wood has recommendations as what to do. I have heard, take it as you want, that treated outdoor wood needs at least 1 year of being in the environment before any kind of finish should be applied.
6/28/22       #5: Painting wet pressure treated ...
orin zelenak Member
My thought was that the water would still have ample surface area to migrate out of. A single 3 5/8" face would be painted. That leave about 60% of the rest of the board exposed.
I would think that the water would migrate (the board would dry) because of a differential in vapor pressure, ie. at the surface of the board liquid water would be evaporating.
Since the painted surface would have a film (somewhat permeable) over it there would be much less tendency for water to seek to evaporate through the film when it has an easy path through all the rest of the exposed, unpainted surface.
But this is just a hypothesis. It would be good to see if anyone with a better understanding of the mechanics of this can show why it's flawed or give an anecdote where they did something similar.
6/28/22       #6: Painting wet pressure treated ...
JeffA
Well, most of us here are just old finishing guys and not scientists. I'm sure someone can give you the answer you are wanting to hear. If not, go for it. Let us know how it turns out.
6/28/22       #7: Painting wet pressure treated ...
orin zelenak Member
6/28/22       #8: Painting wet pressure treated ...
orin zelenak Member
I'm also a finisher. I just happen to be building a fence. I know the general thought is the best result would be painting a nice, dry piece of wood. And I may just test it anyway. But it seems like this isn't rocket science and someone has done or thought through this before. Makes me wish wood came in white...
6/28/22       #9: Painting wet pressure treated ...
Leo G
You'll have to wait until the wood equalizes with the environment. I think that is about 12%. Use a moisture meter and when it gets there paint it with something designed for exterior. If the sun bakes it you should be able to paint it in the fall.
