Subject: Re: Primary Colors in Water Based Stain
7/8/22
Ken Member
Does anyone know where to get the primary colors to mix my own water based stain. (red, blue and yellow) Looking for quart or gallon size.
7/8/22       #2: Primary Colors in Water Based Stain ...
JeffA
Good afternoon Ken. Are you just looking at making your own stains in the 3 primary and 3 secondary colors? Or are you wanting to make wood stains in browns and such? I'm not aware of anyone that has the WB stains in a monotint system that can be used straight up or blended. But if you are looking to make brown stains you will also need black and probably white also.
7/8/22       #3: Primary Colors in Water Based Stain ...
Chris
Check out WD Lockwood stains
7/9/22       #4: Primary Colors in Water Based Stain ...
Gallon size for tint? You don't want to start with tint bases and adjust with minor amounts of tint?
7/9/22       #5: Primary Colors in Water Based Stain ...
Ken Member
Thank you all for your input. It was most helpful. Greatly appreciated.
7/9/22       #6: Primary Colors in Water Based Stain ...
chemmy  Member
HULS is probably the largest maker of industrial pigments in the USA. They have both aqueous and solvent based pigments. Most large Companies like Sherwin Williams, etc., use their canister colors, for color matching.! I'm only familiar with their 896 and 844 series colors and a few specialty colors they make like their synthetic Van Dyke Brown.! But I have set several color labs up with them as well as provided training in their use. Huls America is what they go by, and there colorants are available in gallons or more. They are also expensive.!!
If your doing mainly pigmented colors for matching "wood stains" these are not what I would recommend, most all wood pigmented stains are achieved based on natural pigments, not synthetic pigments. Raw sienna, burnt sienna, raw umber, burnt umber, van dyke brown, yellow ochre, and a variety of natural reds blues etc. Plus black for darkening/shading and white for tinting/lightning.
If your just doing your own color work to offer your clients colors to choose from, then anything can be used.! But if your trying to match other wood stains out on the market, these are not done with standard primary colors.! They are done with the list I just gave you of natural pigments.! Again, on the otherhand if you want to make aqueous " dye" wood stains, that's a whole other matter. And a much longer discussion.
7/9/22       #7: Primary Colors in Water Based Stain ...
Denny J
One of the best systems available are the ICA CNA stains. They have a kit with all of their concentrates and a library of over 200 colors with the recipes for them. From there you can adjust any of them manually. They don’t have true RBY colors though. Renner has a similar, less robust library but very good pigments
    • 2Sand
