Subject: Re: expired catalyst
expired catalyst
7/27/22
Frankie Member
Hello
Wondering if any of you have used an expired catalyst when mixing your lacquer? I use the renner product line and use post cat with the m404 hardener/catalyst. My supplier said it was okay to use after expiry but I ran into issues with severe watermarks (looked like someone poured water over the panels and let it dry) appearing after final topcoat.I still achieved a smooth finish but the marks were visible. I re topcoated everything without adding the catalyst, it took a few re coats but the marks finally disappeared. Does anyone know what the stability is of catalyst after expiry or if it reacts differently.
7/27/22       #2: expired catalyst ...
If it's expired by a good period don't use it. I actually don't believe most chemicals can "expire". But after using a Paslode gas powered gun with the gas having an expiration date which seems absurd.
But on several occasions I've used old gas cartridges and they didn't work. I don't understand how a gas can go bad but it did.
The only catalyst I really worry about is 2K poly.
7/27/22       #3: expired catalyst ...
JeffA
I believe most catalysts are made up with acids of some sort. Acids can loose their acidity over time so that is why catalysts can have an expiration date. Of course the manufacturers will give themselves some protection so they will give a catalyst that can actually be good for a year a 6 month expiration. Makes sense in both liability and sales....
