Subject: Re: Automatic spraying machines
9/6/22
Rich
With the increasing difficulty of getting help and the rising cost of labor I am a believer that in general automation is better. I get that machines bring their own set of issues. I'm wondering if any of you guys have experience with automatic finish machines. We are a custom shop so there are limits to what we can process through this that type of machine. Anyone ever use one?
9/6/22       #3: Automatic spraying machines ...
You can get a curtain coater, or get prefinished plywood, but some kind of robotic arm finisher will be a programming nightmare for a custom shop.
9/8/22       #4: Automatic spraying machines ...
Rick Mosher
I used a Superfici Robotic finish machine at Hollywood Woodwork and Mark Richey Woodworking. We did custom work at both shops and I was able to set up a finish schedule that worked great.
9/8/22       #5: Automatic spraying machines ...
JeffA
Just so you know, automated finishing requires people to run. If you have a small flatline you will need a loader, unloader and someone to watch the spray application. 3 people. Don't think that automated doesn't require people. FYI
9/9/22       #6: Automatic spraying machines ...
rich Member
Website: http://www.handmadefurniturecompany.com
Thanks for the responses so far. I do understand that someone needs to run and service machines. I'd love specific recommendations from people knowledgeable with this type of machines.
9/13/22       #7: Automatic spraying machines ...
MIke Member
Website: http://rulonco.com
We use a Giardina Flat Line reciprocator line and have used it for 17 years with minimal issues. There is direct support in Louisville KY for any issues that arise and the staff is very knowledgeable.
We are using a water based stain and UV cure topcoat. Hope this helps.
9/13/22       #8: Automatic spraying machines ...
Chris
Have you thought about a consulting company like AWFI
They could definitely give you some guidance
9/14/22       #9: Automatic spraying machines ...
JeffA
It wasn't my intention to make a smarky reply. Send me a personal email and let's talk. I have some experience in the wood coatings industry.
9/18/22       #10: Automatic spraying machines ...
herb johnson
rich, you should reach out to the experts at grapek in nj they are local to you and can help you with what you want to do
goodluck
herb j
9/18/22       #11: Automatic spraying machines ...
Chris
Also check out Schweizer and Crosson.
They are also in NJ
https://www.scspray.com
