Subject: Re: Bleaching raw maple
Bleaching raw maple
10/6/22
Julie Member
We have occasional issues with our 2 part bleach where raw maple is yellowing when bleached. The wood is freshly sanded and had no ambering any ideas on how to neutralize tannins or is it something else? Thanks
10/7/22       #2: Bleaching raw maple ...
chemmy Member
If your using 2 part bleach, which I surmise that you are, the mistake most people make is mixing the two together and making a single application and the neutralizing with common 5% white vinegar ( acetic acid). To rid yourself of ending up with the yellowing, which is caused by the reaction of the vinegar on the lye/ sodium hydroxide, causing the excess lye residue to turn color.!
If you instead make a two part seperate application of the lye first, letting it darken the as much as it will, then after it is surface dry, wash of the excess lye with clean water and rags, etc., and then apply the hydrogen peroxide/ bleach, and let it surface dry before neutralizing the lye with the vinegar, that should solve the problem.! If you still have the problem, after doing this, get back to me with what is happening ok.? It may be necessary to thin the vinegar or the lye, but try this first ok.?
Sincerely,
Chemmy
10/7/22       #3: Bleaching raw maple ...
Julie Member
Thanks Chemmy! Will give it a try.
12/5/22       #4: Bleaching raw maple ...
Chemmy,
I’m a bit confused by your process….
So there’s a way to remove the yellow from Maple and make it more “white”?
So is that possible by applying part one wood bleach, then part 2? If so, how long after part one?
Anything else get mixed with either part?
12/5/22       #5: Bleaching raw maple ...
chemmy Member
Hey MIKE, I thought I was pretty clear on this, but will respond anyway.!
First off, the sodium hydroxide, aka ( Caustic soda or lye,) [part 1 of the 2 part bleaching process] when applied to any common woods and most if not all uncommon woods, burns or darkens the wood it is applied to by varying degrees, depending on the tannins in the wood..ok?
Hydrogen peroxide, is actually the chemical that does the lightning/whitening, of the material it's being applied to.! It accomplishes this by an extra molecule of "nacent" oxygen, ( A litely attached molecule) being present in the chain, which when given up will lighten the area it is applied to.
Though you can achieve a good result from mixing the part 1 and part 2 chemicals together and applying them to the wood surfaces, the problem is, especially on woods that are pretty light to begin with, such as maple, birch, etc., is that all of the caustic part 1 lye, may not be fully neutralized or spent, in the process.. Which means that there is or may be tannins still present in the wood surface that are still active, and capable of showing up as a mild to medium yellowness, after the neutralizer, ( acetic acid/ white vinegar) is applied to neutralize any remaining tannins that may be present on the wood surface.! Showing up as a yellowish color, ok.??
On the otherhand, if the two components (1+2) are applied separately, and each is allowed to surface dry in between applications, the excess tannins can be removed from the part 1 lye application independently, simply by using clean water and white rags. This insures to a high degree, that when the surfaces are then surface dried again and the part 2 bleach is apllied...(hydrogen peroxide) that when it is fully dried that the vinegar will not act to leach out any unspent tannins that would exist in a one time application of the parts 1+2 being mixed together and applied simultaneously in a singular procedure.!!!
The main thing to understand in this subscribed process, is not to wait till the wood surfaces are completely or thoroughly dried, but just to where no part of the surfaces still look wet, before washing the surfaces with clear clean water and white rags, the rags are needed to see and show if any off white residue is being picked up/ removed from the surfaces...ok.? If, and when, no color is being removed from the surface, then the peroxide (part 2...can be applied and again when surface dried and the vinegar can be used without concern with it turning the wood yellow. If by chance it still turns yellow, it would only be because the concentration of the vinegar is to high.! Usually in this case I outline, if the tannins are virtually all removed, their is no need for a 5% solution of vinegar being needed, A one or two percent solution of vinegar would be more than sufficient.!!! There is also what I deemed back in the late seventies, A method I called " Hyper-Bleaching" which introduces an even whiter final product on the wood surfaces....but much caution is needed in using this method which is done with high heat.!!
I can give you little more help or understanding in this Mike, I hope this time I made myself much clearer in understanding this process, and that this can be used on virtually all woods, not just light colored woods ok.?
Sincerely
Chemmy
12/12/22       #6: Bleaching raw maple ...
Jon W Member
I have found that after bleaching/neutralizing, treating with oxalic acid should solve the problem.
    • 2Sand
