Subject: Re: Tip size for kremlin
10/15/22
Travis Alfrey
I spray mlcampbell post cat cv in kremlin airmix. What tip size are you using. I have always sprayed most things flat so the amount that is coming from the tip did not matter as much but now I am spraying more assembled things vertically and am curious on tips. I use 09-134. Thanks
10/15/22       #2: Tip size for kremlin ...
herb johnson
that is wide tip, what size parts are you spraying. mostly likely if you r spraying vertically all you might have to do, is just speed up ur stroke a little.
good luck
herbj
otherwise next size down is a 6-134 and take out the black microscreen and use the white tip, rarely is the microscreen needed
10/15/22       #3: Tip size for kremlin ...
Travis Alfrey
Cabinets mainly. I do have a more narrow tip but it is still a 09. Are you talking about the screen on the inlet of the gun??
10/15/22       #4: Tip size for kremlin ...
I use Stealth and shoot with a 14-10 Kremlin. I use the 815 CAT tip (12-174). Works well for bigger stuff. Wish there was a 09-174 but they only have a 09-154.
10/17/22       #5: Tip size for kremlin ...
herb johnson
yes, the black microscreen, if your doing narrow stuff like 06 -074 with a white tip seal 20 air pressure 50 fluid on a 10c 18 ymmv
10/19/22       #6: Tip size for kremlin ...
Herb,
Thanks for the info, does the screen in the 06 tip work as a filter as well?
I spray Envirolak with the 06 tips, but never crossed my mind to use the white o-ring.
10/19/22       #7: Tip size for kremlin ...
I use the screen in the 12 series tips. I never strain my paint or clears and I'm glad I have both the gun and the tip screens. I never get a tip clog from something that made it through.
I do know that I have to clean the tip screen more often when I spraying pigmented using the 12 tip. Not that much of a hassle.
Knew a guy that didn't use the screen and he was always complaining that his tips were getting clogged. Especially after one time he put stripper in his system to clean it out. He never heard of the screens for the tips until I told him about them. Never had a problem after putting one in.
10/20/22       #8: Tip size for kremlin ...
Color Inc Member
09-114 09-134 09-154 98% of my finish uses these tips. i personally use the 09-114 for most everything and the 09-134 for the rest. the screen tip seal come in 2 micron sizes. these are problematic imho. The mesh filters in the swivel come in 2 microns as well i use the finer micron in the gun as well as a mesh boot around the fluid wand. i only strain Gloss. this gives me fairly clean finishes.
10/20/22       #9: Tip size for kremlin ...
herb johnson
i find the micro screens un necessary....... just my two cents. you have the screens in the gun handle three sizes ending in 907 908 and 909 ranging from course to extra fine, 908 is the medium
keep it simple for me. one less thing to inventory
