Subject: Re: matte finish getting polished from finger touch
11/2/22
Michael Member
Has anyone every done a matte finish on touch to open cabinetry? I did a kitchen about two years ago and the matte finish is getting polished to a higher sheen where it it touched to open. I'm trying to figure out a solution. The finish we applied was ML Campbell Turino flat sheen that my rep matched and added additional flattening paste. The color/sheen was matched from a sample of Zenit prefinished panels available from Richelieu, and the match is exact. Currently we are trying to replace some of the most used panels with edgebanded Zenit material. The spec on the Zenit material says is a lacquer finish on MDF, so I'm not at all confident that it will withstand polishing any better than our conversion varnish on MDF finish. This is all getting done on the customers dime, so the bottom line is not an issue.
Anyone have experience with Zenit material in a touch to open kitchen? Or matte finishes getting polished from use? I'm afraid its a situation without much resolve other that adding exposed hardware, but the customer already spent ~$15k on Blum servo drive components to avoid that.. Any suggestions would be appreciated!
11/2/22       #2: matte finish getting polished from ...
You won't like it. Maybe spray everything with Krystal in a dull sheen. Much easier to repair. Or wet sand everything with 1000 grit.
11/3/22       #3: matte finish getting polished from ...
chemmy Member
Dull, flat, matte, finishes of any kind, even polyester, will shine up with repeated rubbing.!
Frosted glass would be the best bet for very long term, if not indefinite matte effects. The best you could do is to sandblast the areas with a pasche mini airbrush using very tiny abrasive particles and low pressure which I have had to do in a few instances on pianos and guitars. But as I told the clients it is no more of a permanent fix than re-spraying the entire piece, which would still not solve the problem.!
The only other suggestion I have is to put some type of decorative metal or frosted glass touch plates on all the doors and drawers.!
