Subject: Re: Do you leave water/DNA in pump?
11/11/22
Mastercabman
Hello all,
I've decided to go waterborne
I am switching my CAT pump from solvent to waterborne
I cleaned it, replaced the pickup tube assembly and fluid hose
I understand that when it's time to clean the pump I just use water till it runs clear and then do a rinse with water/DNA mix
Couple questions
Anything else I need to do to clean?
Do I leave anything in the pump until the next session?
I used to leave lacquer thinner in the pump when using solvent
I'm now using MLC Arroyo
11/11/22       #2: Do you leave water/DNA in pump? ...
herb johnson
all cat pumps have nothing that can rust, only other suggestion would be acra strip which i love, but many use simple green, acetone fifty fifty, etc.......also not a bad idea to run things by a knowledgeable if u can find tech rep from mlc who will most likely recommend their equivalent to acra strip.....fwiw
good luck herb j
11/11/22       #3: Do you leave water/DNA in pump? ...
Mastercabman
Thanks Herb
I think I have some of that acrasrtip
I know MLC have something very similar
So I guess I just keep some of that stuff in the pump and just reuse?
11/12/22       #4: Do you leave water/DNA in pump? ...
herb johnson
i would strain the chunks, your cat will be fine! about 50 fifty water
11/12/22       #5: Do you leave water/DNA in pump? ...
Herb,
I can’t find anyone who sells acts strip in my area, any idea what ratio of simple green you would use?
11/12/22       #6: Do you leave water/DNA in pump? ...
herb johnson
not sure to be honest, i recall some saying on here like the same as acrastrip but dont recall
11/13/22       #7: Do you leave water/DNA in pump? ...
Herb,
11/13/22       #8: Do you leave water/DNA in pump? ...
herb johnson
look online, there are many
11/13/22       #9: Do you leave water/DNA in pump? ...
Thanks Herb, I have no idea on how I reposted that message again. Sorry all.
11/22/22       #10: Do you leave water/DNA in pump? ...
John Bishop Member
I run about 10%simple green (the purple HD version) with water in our CAT pump and hoses and have no issues as long as it gets a good flush first. Usually flush first with water then the 10% mix. Been doing that for years now with good luck.
    • 2Sand
