Subject: Re: Dark paint dry times
11/23/22
JM
Hey all.
I'm doing a split color kitchen. White on walls, dark naval blue on bases.
Using ml Campbell. Yesterday i sprayed the naval blue on the backs. (Turino clear satin tinted to a dark blue - so decent amount of colorant added. )
I wanted to spray faces today. So I'd pull a door off rack scuff the face put in rack face up.
Then came time to start painting and as I grab the doors of the rack, they're sticking to the rack pretty bad. Leaving marks and in one case pulled paint off the back.
The backs had a chance to dry for 20 something hours before flipping them.
Once flipped the doors sat on that coat for less than 5 mins and they're sticking to the rack.
I know for a fact I catalyzed correctly since I do double checks on that.
I did retard 10% too.
Is there something to the amount of colorant used in the mix causing the dry time needing to be longer?
My only other idea would be to lock it in with a clear coat?
I had done the white same time and no problems at all.
Any thoughts are appreciated.
Thanks!
11/23/22       #2: Dark paint dry times ...
Mastercabman
Sorry about your problems
I've use Turino and really love it
But man,20 hours and still sticks to the racks?
Personally when it comes to dark color I get my primer/sealer tinted to the color and then clear top coat
Hope you get your issue resolved
11/24/22       #3: Dark paint dry times ...
FM
I’ve never used Turino but all the other MLC products I’ve used and a few other manufacturers have this same issue with dark colors. Basically anything in a clear base with a ton of pigment added to achieve the color. Best way I have found to deal with it is add more heat, more air movement and allow more time. Then even after in the shop be cautious on stack and wrap times.
If you clearcoat it what’s underneath will still be soft in the same timeframe so you have to take the same precautions.
11/24/22       #4: Dark paint dry times ...
FM
Also lower sheens will due better than higher sheens. If you can shoot flat it will speed this up by half.
11/24/22       #5: Dark paint dry times ...
Bart
I concur that deeper based colors definitely are softer and take more time to cure. I would ask what type of racks are you using. My racks are 3/4 oak dowels. I always let my doors dry overnight on the final coat to the backs before the final coat on the faces. Especially on heavier doors like MDF slab doors and big panels.
Also I've always wondered about clear coating over pigmented finishes. Putting a much harder clear coat over it seems to violate the never put a hard finish over a softer more pliable finish "law".
my2cts
11/24/22       #6: Dark paint dry times ...
JM
Thanks for the responses. Looks like I just need to let it sit. I had let it sit overnight. If approximate that it was around 20 hours between.
I'll try to wait a few days...
This is the rack in using. But i added cardboard to try to soften the metal bar it sits on.
https://thepaintline.com/collections/drying-racks/products/prodryingrack
11/24/22       #7: Dark paint dry times ...
FM
Blue painters tape works 100% better than cardboard but it’s a pain to clean off racks.
12/2/22       #8: Dark paint dry times ...
Jim Kolar
We spray Torino. I can spray Iron ore from sherwin williams and have to do three light coats. Two much mil thickness and I have serious dry time issues. I can spray the color Iron ore from SW and no problems. So anytime we spray dark colors we do samples pieces and test. Little extra work but well worth it. I can't explain why one dark color is more work than the other, but the testing is our standard and has made a difference. Torino has been a good product.
Good Luck
12/2/22       #9: Dark paint dry times ...
Jim Kolar
Correcting my post. I meant Tri corn black as good dry times not Iron ore
12/12/22       #10: Dark paint dry times ...
paul cook
Had the same problem with ML Campbell product(not Turino),
the color was a dark brown(similar to M&M brown).It wouldn`t
completely dry.Campbell rep told me that this color was
overpigmented,suggested I topcoat with clear.This fixed the problem in about 4 hours dry time.
12/12/22       #11: Dark paint dry times ...
JM
Hey Paul
Did you have any issues come back after putting clear over?
As a previous poster said putting hard over softer is tough.
Assuming no issues popped up on you?
12/12/22       #12: Dark paint dry times ...
paul cook
no I didn`t,the clear worked for me.
12/17/22       #13: Dark paint dry times ...
Daniel Shafner  Member
Turino dark (clear base) sux, period. It stays sticky for days. We had the heat on 100 deg F, plus fans, and to no avail.
Stealth or Resistant darks (clear base) both have NO stacktime issues. Only Turino clear base does this.
As for racking, place your doors on clean & flat sheets of MDF. The weight of your doors and panels are distributed throughout the surface area of the MDF panel instead of being concentrated at the apex point of dowels or wire rod shelves.
