Subject: Re: Retarder for CV same as acrylic?
12/8/22
Craig
I have a Conversion varnish retarder, lots of it. Doing an acrylic job but it's drying too fast. I tried the retarder from the CV system in the acrylic.
It didn't fish eye or seem to react negatively on a test piece. Is a solvent retarder the same across nitro/CV/polyurethane/acrylic? Thanks
12/9/22       #2: Retarder for CV same as acrylic? ...
Poly uses different solvents. Acrylic usually means waterborne so that would be a hard no. But if it's not a waterborne then it might work. But I'm sure the brand will not warranty it if you use and out of system thinner/retarder.
12/10/22       #3: Retarder for CV same as acrylic? ...
Craig
Thanks! It's an ICA acrylic. Solvent based.
I tried it yesterday..
It didn't seem to have any ill affect. Not sure if it compromised the finish hardness etc.
Trying to get a proper slow acrylic reducer..
12/11/22       #4: Retarder for CV same as acrylic? ...
Jason
By acrylic, do you mean cab acrylic lacquer? If so, the retarder for that is mostly mak. I think conversion varnish retarder is mostly butyl acetate or a combination of the two. If you didn’t have a reaction, you are probably ok.
12/11/22       #5: Retarder for CV same as acrylic? ...
masterblaster
Retarder is a general term not a solvent. look at the msds sheet for the product and check flash times of the solvents in the coating. add more of the slowest solvent is the safest way to do it if not sure if a general "retarder" will work.
you may also try spraying a little heavier over the hang coat, that will help cut down on the overspray. The type of spray system will also make a difference.
