Subject: Re: Lenmar waterborne
Lenmar waterborne
2/10/23
Mastercabman
Any of you uses or used Lenmar waterborne?
Can you tell me more about
Good? Bad? Just ok?
I switched to waterborne a few months ago
I tried the MLC Arroyo and like it very much
I also tried the Renner brand and I'm having some mix feelings about it but I did like the finish
So please tell me more about Lenmar waterborne
I have used their precat before and seems to be Allright
2/12/23       #2: Lenmar waterborne ...
Joe W. Member
I recently switched to Lenmar Duralaq. I had used ML Campbell Waterborne for years. Agualente & Agualente Plus, then Magnamax H20. I was pleased with both, but due to supplier issues and cost increases, I tried Lenmar. I am very pleased with it so far. I have used it for about a year now.
I spray with a CA Tech Air Assist 14 to1 Right out of the can. I have not had any issues yet. No problems getting it. Cost is much cheaper. Drying time seems longer though.
Very easy to use. I have only used precats and waterborne (15 yrs +) so I can't compare to anything else.
2/12/23       #3: Lenmar waterborne ...
Mastercabman
Joe W
Thanks for your feedback
I also have the same set up as you
I am also having issues with getting Arroyo if it needs to be tinted
My local Wurth group does not have the colorant machine so it has to be mix at another location and they are backed up with orders
I can get the lenmar products locally
So I might just go ahead and get a gallon to try out
