Subject: Re: VOCs, HAPs, Flashpoint
3/2/23
Brent Member
Website: http://www.parkhillwoodcraft.ca
I already asked my finish rep and he wasn't completely helpful. Can anyone point me to a resource to educate myself on VOCs, HAPs, flashpoints, etc as they relate to clear topcoats? I've been spraying MLC and Sherwin Williams water borne coatings for about 4 years now, and have recently had to switch to MLC's new Arroyo for my clear topcoats. I'm getting very frustrated with the WB coating results and am considering switching to solvent based as I already spray my solvent stains and vinyl sealers used under the WB topcoats. I feel like I waste so much time controlling, troubleshooting and fixing WB coating defects. Sure water cleanup is nice and it's environmentally friendly, but I'm still here to make money. No I am not using an approved booth/fan system; rather, I'm using a very large inline motor barn fan in my current booth. The shop is heated with a wood stove so there is technically an open flame. Insurance concerns are a non-issue.
I've been spraying vinyl sealer now for over a year with very nice results and I still here to tell the tale. I'm looking to understand the dangers associated with switching to a solvent borne system as they relate to my current exhaust and heating system.
3/2/23       #2: VOCs, HAPs, Flashpoint ...
CraigM
The attached article should answer your questions. There's been a few more similar situations in Vancouver in the last 15 years that I know of as well. There's a reason finishing operations cost $10's to $100's of thousands of dollars to set up properly (and legally). Pretty much all solvent finishes are Class 3 Flammable liquid, so it has a flash point of 37.8C (the minimum temp that the vapours will form an ignitable mixture with air near the surface of the liquid). Having a woodfired stove for heat is not a matter of if you'll have a fire, it's a matter of when. If you can't set up a shop that can handle solvent products, look into Envirolak or the Italian companies (Renner, Ilva, Milesi, ICA ect.) they all make high quality WB finishes.
PG Spray Booth Fire
3/2/23       #3: VOCs, HAPs, Flashpoint ...
Brent Member
Thanks for the article Craig. Do you have a suggestion on dealers for those companies you mentioned? My typical supplier (E.Roko. and Richelieu) do not carry these supplies unfortunately...
3/2/23       #4: VOCs, HAPs, Flashpoint ...
CraigM
Sent you a DM
