Subject: Re: On-site spraying
On-site spraying
3/3/23
Amit Member
Website: http://cabstore.ca
Hello all,
I have a bit of a problem. I installed a kitchen (cabinets and uppers)… then I sent someone to install the crowns after the and had someone then die counters were installed.
When I went to visit the site, I realized the shade of the crown was different than the shade of the cabinet doors…
Has anyone experienced this issue in the past and if so, how have you resolved?
I finish in post catalyzed lacquer. My first thought is to go back, tape, everything off of plastic… And spray the crown… I normally spray in the spray booth and I am not comfortable spraying in someone’s house… If I use this method, is there a special gun I should be using? Special tip? Special method?
3/3/23       #2: On-site spraying ...
Mastercabman
First thing first,
Are you sure that the paint used is different?
The reason I'm asking is that light reflection can trick you
What I mean is that if the surrounding color of wall for instance it could reflect in different shade by natural light from large windows
On the other hand, if it was sprayed with different color than I would just use a hvlp gun with 3m pps cup
You will need to tape off and protect anything below
You can use a vacuum to suck up over spray as you go along
Hope this helps
6/21/23       #3: On-site spraying ...
J
I have had crown on a job look different before. If hold it up against the door flat and the color was spot on. But when I angled it at a 45 to imitate it being hung in position, that 45 degree angle somehow caught light differently and the paint looked a different color. Bizarre but it did happen to me too.
Luckily client accepted it after proving to them it was the same color.
