Subject: Re: Gel Stain after sanding off only part of old finish?
4/2/23
cathammer Member
I need to refinish the top of an oak dining table that has some long but shallow cross-grain scratches through the finish, but is mostly in good shape otherwise. Removing them will necessitate sanding slightly through the existing (poly?) finish and stain in the area of the scratches. I have a gel stain that should closely match the existing color.
Question is, since I'll have to sand through at least part of the existing finish rather than just use the gel stain over a lightly sanded but intact old finish, will I actually need to sand down to wood on ALL the old surface before staining to avoid an uneven looking final appearance?
Thanks for any suggestions!
4/4/23       #2: Gel Stain after sanding off only pa ...
Dave Edgerton  Member
A pro shop would strip the entire top, resand and redo.
4/5/23       #4: Gel Stain after sanding off only pa ...
chemmy
I agree with Dave.!! To many unknowns, to many things that can go wrong and cost u time and money.! I would list all the problems with attempting what your doing, but I will wait and see if others jump in to do that for me.!
4/5/23       #5: Gel Stain after sanding off only pa ...
Bart
I'd try and talk them into clear coating it. You could just scuff sand it and spot prime or fill the scratches with epoxy and clear coat it a 2-3 times. Otherwise you're biting off whole lotta pain/mess.
my2cts
4/5/23       #6: Gel Stain after sanding off only pa ...
cathammer Member
I think you're right (Dave, chemmy)
Played around a bit on the underside of a leaf, and blending in multiple sanded out spots would just be too time-consuming and unlikely to produce acceptable results. Some short scratches could be left in as part of the look , but the long ones, in not-quite matching areas, just look like the recent damage they are.
Thanks!
4/6/23       #7: Gel Stain after sanding off only pa ...
chemmy
Good call Cathammer, A wise old finisher once said to me..."When in doubt..strip and refinish.." That was my Father.! The same entity that also told me..." When you learn to see with your hands and feel with your eyes, then you will know you are no longer an apprentice, you have become a journeyman.!" I didn't know then exactly what he meant, but within a decade or so I became a journeyman...and eventually a master, but that's a topic for another time and place.
