Subject: Re: Kremlin 10:1 short stroking
6/22/23
Al
Website: http://thecarpentershop.net
I bought two kremlin 10:1 spray pumps and guns about five years ago and one has worked flawlessly ever since, shooting tinted lacquer sealer/undercoater (thick paint), usually Mohawk. The other one stays set up on clear finishes, vinyl sealer and pre cat, again usually Mohawk. The clear gun developed a problem probably in the first six months, at first it would start working okay after a few minutes of short stroking on the pump. What in the heck do I mean by that.
So you turn the air valve on and start spraying and get maybe two square feet of panel wet and the fluid pressure starts dropping till it stops spraying. Air fan pressure stays fine. The pump itself starts a downward cycle with a little noise, heads down and stops short of the bottom of the stroke. Walk over to the pump, turn off the air to the pump, wait a second or bleed the pressure off by triggering the gun, and the pump completes the stopped stroke and you can spray another two square feet.
Fluid pressure set at 7 psi, air pressure on the right side of the pump is set on 15 psi. Varying the pressure has little to no effect on the short stroking.
At first it would "warm up", you would fiddle with it for five minutes and it works fine if but a little slow on the down stroke. Pull the cap and nozzle off and trigger the gun it pumps fluid like mad. Nozzle isn't clogged, switch the cap and nozzle to the paint pump and it works perfectly. Filter at the entry point of the gun is clean. There is oil in the bottom of the pump, the air is clean and dry coming into the pump.
Adding quite a bit of thinner sometimes helps but that isn't good.
Any ideas on how to fix this thing?
Al
6/22/23       #2: Kremlin 10:1 short stroking ...
joe
sounds like something is clogged. do you have a filter at the tip of the gun, the filter at the base of the gun where the fluid enters the gun?
If it isn't those filters. unscrew where the pick up hose enters the pump. Then unscrew the cylinder that the pick up hose is attached to. there is a ball valve at the base of that cylinder that could have dried crap stuck in there. if it isn't that ball valve, When you unscrew the cylinder you will also find a piston type rod with a plastic seal at the bottom. hold the piston rod and unscrew that plastic seal. That plastic seal assemble has 4 pieces altogether. unscrew the metal on the top from the metal on the bottom. that releases the plastic seal valve and opens up the next ball valve assembly. Its a tiny ball, like BB sized. I would almost guarantee that this has crud built up in it.
6/22/23       #3: Kremlin 10:1 short stroking ...
Joe
I also want to add, take great measure to preserve all rubber seals and do not soak them in anything. they almost instantly get ruined if they touch solvents.
6/22/23       #4: Kremlin 10:1 short stroking ...
Al
Thank you. I knew about the large ball valve in the bottom of the cylinder where the pump picks up the paint but not about that smaller ball valve. I will strip that down this afternoon and give it a good cleaning. The o rings and seals get greased upon re assembly, correct? I bought a can of that special lube a few years back just in case.
6/23/23       #5: Kremlin 10:1 short stroking ...
Very good chance it's one of the two ball valves. Short stroking is usually caused by the lower intake ball not seating properly. Another thing that can happen is crud gets stuck in the nylon piston. This makes the piston larger and makes more force against the cylinder wall making it hard for the piston to travel up and down. There is a wrench hold on the bottom of that that will release the nylon piston which is also where the BB sized ball is. Be careful you don't drop it and lose it.
Another problem with older systems is the pickup tube becomes very narrow as the paint builds up on the internal walls. Mine is about 15 years old and it was narrowed down to less than a 1/4". I'm sure this makes it tough for the pump to move the material.
I sent my pump in to repair the air motor and the guy said it was working perfectly. At my shop it could barely function. After it was returned it worked pretty good for a while. And then the issues started to return. After I deducted that my tube was clogged I figured that while the pump was out for repair the paint in the tube dried up and shrunk back. And when I started to used it again the paint swelled back up I started to have the issue again.
I drilled out the pickup tube as best I could and it's working much better now. The rubber pickup tube was spotless.
