Subject: Re: finishing
finishing
6/26/23
Kevin Campbell
Looking for advice on finishing. what is best to use for repainting an art deco dressing table with ornate legs.
6/26/23       #2: finishing ...
chemmy
Not enough info...what type of finish was or is on there now.? Is it a pigmented finish or clear, ? If U can provide photos.... Is this American art deco or French/European.? Walnut or other wood(s).?
7/21/23       #3: finishing ...
FGT CABINETRY LLC (IOWA) Member
The best finish for your dressing table will depend on your personal preferences and the environment in which the table will be used. If you are looking for a hard, durable finish that will protect the wood, then lacquer or polyurethane is a good option. If you are looking for a natural finish that will allow the wood to breathe, then wax is a good choice.
Here are some additional tips for finishing an art deco dressing table:
Use high-quality materials. The quality of the finish will depend on the quality of the materials that you use. So, be sure to use high-quality paint, lacquer, or wax.
Apply the finish in thin coats. It is better to apply several thin coats of finish than one thick coat. This will help to prevent the finish from cracking or peeling.
Allow the finish to dry completely between coats. This will help to ensure that the finish is evenly applied and that it will not chip or peel.
Protect the finish. Once the finish is dry, you will need to protect it from scratches, moisture, and sunlight. You can do this by applying a clear coat of lacquer or polyurethane.
I hope this helps!
