Subject: Re: Booth exhaust termination
7/3/23
Chris
We just got a new spray booth and it looks like venting it through a wall is going to be better than going up through the roof. I’m not sure what the proper end cap/ damper should be for a horizontal termination like this, I’ve only ever seen them go through the roof. Anyone’s booth exaust going through the wall? A picture would be helpful. Thanks
7/4/23       #3: Booth exhaust termination ...
No matter what direction you point the exhaust, a good electronically controlled damper is worth the money. The fans and stacks can be quite large, and that makes for trouble in the humid summer and cold winter days. The trouble comes from high booth humidity and problems with air make up temperature control in the winter. I hope you put in a variable speed blower or blowers. Makes a huge difference when just removing off gassing vapors in the winter.
7/9/23       #4: Booth exhaust termination ...
Kevin Dunphy
Website: http://www.kdunphy.com/
You have to have 6 feet to 4 feet above the roof .
Out the side of the building, the exhaust will blow back into the building. Its common sense
With the power of those fans, there is no power loss going straight up
Curios where you got your information
7/17/23       #5: Booth exhaust termination ...
chris
i have my exhaust going through a wall. During installation i thought I had to go over 20' high to top of building but my supplier 'who has over 30 years of experience told me that i could go through the wall.
It was approved by the town and fire inspector.
7/17/23       #6: Booth exhaust termination ...
Kevin Dunphy
Website: http://kdunphy.com
Below the link is the primary airflow it is 101 no degree is needed.
Is this a professional spray booth?
My booth has 3 steel jacks that hold up the motor fan and the exhaust, the exhaust on top has a flap to keep the rain out but opens when the fan is turned on.
I had a windstorm hit the shop the winds were over 70 mph or over 100 kilometers, and the wind was so strong it made the round exhaust square yes. Scary not the word I saw roofs detach from houses , but no damage to the shop not shingle gone
Use common sense experience is only good if it's used or it's just a number, I'm surprised a fire marshall would sigh off
Is anyone else with this new system ? I did mine over 15 years ago
https://i.ytimg.com/vi/AFNfW3Bs3CM/maxresdefault.jpg
7/18/23       #7: Booth exhaust termination ...
chris
yes it is a professional booth.
I have never had winds which are stronger than the air which is blown out by the exhaust fan so how can fumes travel back inside?
just curious.
7/18/23       #8: Booth exhaust termination ...
kevin
Its not the exhaust out but the fumes being exhausted are as low as the building depends on wind and humidity could come back .
I remember in Montreal there was a miracle product for floor fast drying it was lacquer but added extra solvent so it could flow out on floor. I was the job after this stuff was layed down couldn't breath .
THERE FIRE IN HOMES BECAUSE OF THAT PRODUCT BECUASE THE FUMES [ARE HEAVIER THN AIR ] WENT IN THE BASEMENT THE PILOT LIGHT WAS ON THE FURNACE SET IT ON FIRE WHOLE HOUSE TOURCHED.
That product is no more
