Subject: Re: 3m 100’ hose for supplied air
7/7/23
Al
I have the 3M 50’ low pressure but am looking for 100’
Prices on web range from $300 to $700. Item # is 3M W3020-100
Anyone bought one lately?
Thanks,
Al
7/7/23       #2: 3m 100’ hose for supplied air ...
Can't you put a coupling between 2, 50' hoses?
7/7/23       #3: 3m 100’ hose for supplied air ...
Al
According to 3M and Allegra directions, 2 hoses cannot be put together. They don’t say why just not to do it.
7/8/23       #4: 3m 100’ hose for supplied air ...
Of course. You have to buy a 100' instead of another 50'. I'd assume they don't want the reduction in the air flow through the connector. But a thin wall piece of stainless steel tubing is hardly going to reduce air flow.
7/14/23       #5: 3m 100’ hose for supplied air ...
chris
just curious as to why you need such a long hose?
can't you move the air supply closer?
seems it would be very easy to get a kink in a hose that long.
7/22/23       #6: 3m 100’ hose for supplied air ...
Oliver
I've connected two together for a on site spray I did, I'm here to report that I survived. Do whatever makes you comfortable but in my mind there is no reason you can't just use a coupler between them. As long as enough air is reaching your hood then you're good.
7/23/23       #7: 3m 100’ hose for supplied air ...
Al
I wound up getting the 100’ hose from a safety supply company in Connecticut. The 50’ hose is in one area of shop and the 100’ serves another. The air pump is set up between the two. One hose goes one way the other in different direction. The 50’ is attached to ceiling and not easily removable.
For those interested in supplied air systems I’m close to $2,000 investment. I wish I had done this years ago. The pump is 3/4 hp Allegro brand, shied, hard hat and hoses are 3M. I’m only using one hose at a time but Allegro says if using two hoses at once that hoses need to be same length. Pump is pretty heavy, mine is set up in permanent place. It is noisy! I put it in place with clean air and there is a door on room so noise isn’t a factor.
Hose fittings are 7/16” npt , local plumbing supply didn’t carry 7/16”. Airline fittings are 1/4”, 3/8” and 1/2”. The 7/16” fittings are hard to find.
7/26/23       #8: 3m 100’ hose for supplied air ...
chris
how long can these hoses be used before they should be replaced? mine is probably 10 years old. Should i replace it?
thanks
    • 2Sand
