Subject: Re: Automotive clear coat polyurethane heat resistance
8/13/23
Ed Member
I have read posts here about many guys using automotive clears. as topcoats on wood with good results. I would appreciate any experience concerning their resistance to heat. Specifically being used on commercial tabletops. I have a customer with solid oak tables that I am refinishing. I have been using General Finishes products gel stain oil based, and Enduro 2k poly. I finished one table 2 coats satin, as a test and it has failed (white heat marks) 7 days after a 7 day drying period. I know the customer and they do not do Fajitas or extremely hot items just porcelain serving dish with hot product. I am looking into the clear coat route for a possible solution. Any suggestions would be appreciated.
8/13/23       #3: Automotive clear coat polyurethane ...
Automotive finishes will not be flexible enough for seasonal wood movement on table tops. Sure steel cars expand in the heat, but the coefficient of expansion for steel is far less that seasonal wood movement. Putting oil based stain under water based clear is likely your problem. How long after staining did you clear coat?
8/14/23       #4: Automotive clear coat polyurethane ...
Michael Folan
We use a 2k floor varnish (Ronseal Diamond Coat) on bar tops where plates and hot whiskeys leave white rings. Never a problem
8/14/23       #5: Automotive clear coat polyurethane ...
Ed
I waited two days 90deg in my closed shop. Then applied the 2k enduro. I believe you are correct, I do not have much experience with these products. I just try to follow the manufacturer's recommendations.
their Gel Stain under the Enduro after a 24 to 48 hour dry time was supposed to be sufficient. But I am
learning things are both art and science.
thanks
8/14/23       #6: Automotive clear coat polyurethane ...
Ed Member
Michael Folan
Thank You for the lead, I appreciate it. Do you apply it over stains, and if so are they water based?
8/15/23       #7: Automotive clear coat polyurethane ...
Michael Folan
Normally over solvent based stains but I can't see why it wouldn't work over water based as long as its dried out. Check to see if surface MC is below acceptable level.
8/24/23       #8: Automotive clear coat polyurethane ...
Jim Knowles
Michael Folan
Are you spraying that floor finish? If so how do you reduce it?
8/25/23       #9: Automotive clear coat polyurethane ...
Michael Folan
HVLP spray gun or sometimes just compressed air. Thin as necessary usually 10%, but could be a little more as it will flash off anyway.
Strain finish through a new micron filter every time.
