Subject: Re: Wood filler for Conversion Varnish
8/16/23
Joe Eberle Member
Website: http://jeberlewoodworking.com
I have been having some trouble with top CV wrinkling over areas that are filled with various wood fillers...
What is your go-to filler for cracks/ joints under conversion varnish?
I've triedthe following:
-Titebond II (and III) mixed with sanding dust but it dries too slowly.
-DAP Plastic Wood wrinkled on some (even when left to dry overnight).
-Bondo All-Purpose Putty and Minwax High Performance Wood Filler were okay but not long enough 'open time' for filling multiple doors.
-Regular old Minwax Stainable Wood Filler was too course and just got sanded out of small cracks...
-We used CA Glue (Titebond and Starbond) but that is expensive with the glue and accelerator.
Any others we should try?
Thanks in advance.
-JJE
8/16/23       #2: Wood filler for Conversion Varnish ...
You might want to post the brand and if it's acrylic or solvent based CV.
8/16/23       #3: Wood filler for Conversion Varnish ...
Joe Eberle Member
We use solvent-based ML Campbell Turino.
8/16/23       #5: Wood filler for Conversion Varnish ...
Famowood is my go to.
8/17/23       #6: Wood filler for Conversion Varnish ...
Leo G
Elmer's E849D8 Carpenter's Interior Wood Filler, not the stuff with wood fibers which is too coarse and not smooth and creamy.
Bondo or equivalent for larger areas
CA glue with an accelerator for some but rare for me.
8/17/23       #7: Wood filler for Conversion Varnish ...
Bart
Haven't used it under CV but I've been using Timber Mate for years. They all shrink, even bondo. The best bet is to let them all cure over night. More cure time is always better. Not sure what coat you're filling but I would never fill before the last coat.
8/18/23       #8: Wood filler for Conversion Varnish ...
The number 1 thing people don't get with filler is the hardness. If the filler doesn't match the surrounding substrate you will get telegraphing. Mixing glue with sawdust is generally much harder than wood. Bondo is likewise harder than wood. It also eventually shrinks, unless you leave a lump for a week to cure then sand it.
If you are doing paint grade the best method is to use a filler that matches the primer coat.
We use Zar & Timbermate.
8/20/23       #9: Wood filler for Conversion Varnish ...
duster
Another vote for Timbermate. It shrinks less than anything else we've tried. No compatibility problems with precat or CV.
8/21/23       #10: Wood filler for Conversion Varnish ...
Joe Eberle Member
Alright, Im going to try the Timbermate and Famowood... I will report back after I run them through their paces.
Thanks everyone for your help.
I appreciate it.
-JJE
8/21/23       #11: Wood filler for Conversion Varnish ...
Bart
The Famo solvent absolutely shrinks more than TimberMate and IMHO doesn't dry as hard and seems to be more porous. Plus it drys up in the can beyond salvage if you don't use it for awhile. I've got a jar of 3yr old white TM still working fine.
my2cts
Cheers
8/21/23       #12: Wood filler for Conversion Varnish ...
Joe Eberle Member
Much thanks, Bart!
-JJE
8/21/23       #13: Wood filler for Conversion Varnish ...
Famowood absolutely does not dry beyond salvage. First you keep the lid on tight and the rim clean. When you notice it getting dry, add some lacquer thinner in the can and the next day it's like new. If you don't touch the can for a year and let it become a rock, then you still add lacquer thinner but wait a couple of days. I guess I don't know just how big of crack is being filled. If it's bigger than hairline, then I make a new part. Famowood does not shrink much if you are filling hairline cracks. I always overfill a bit and then sand it flush when it's dry anyway.
8/21/23       #14: Wood filler for Conversion Varnish ...
Bart
Come on Rich. Been there done that. If I'm doing stain and clears that don't match the Famo color I might not open a can for months. I can't tell you how many partials I've burned through. Is what it is.
TimberMate has them over a barrel for life expectancy and quality.
Cheers
Bart
8/22/23       #15: Wood filler for Conversion Varnish ...
It's your choice to let them go rock hard Bart, but not everyone chooses to do that.
8/22/23       #16: Wood filler for Conversion Varnish ...
Leo G
Timbermate comes in a glass jar, right? Probably a much better seal than the metal can which is why Famowood goes hard after a while even in a sealed can.
I find Famowood to be too hard sanding for just filling holes. If you need to put a screw or fastener in it that's where it might shine.
8/22/23       #17: Wood filler for Conversion Varnish ...
Yavuz Member
Elmer's E849D8 all day long. No shrinking,no compatibility issue,fastest drying and smooth as silky sanding .Conversion Var. or PreCat Lac. or any 2k polys.
One can argue but trying is believing. I suggest order from Amazon and give it a try.
Good Luck !
