Subject: Re: Sanding BB before undercoat/sealer?
8/23/23
Michael Member
I am using BM alkyd undercoat/sealer. I do usually sand my plywood but have never used BB for customer cabs before. The customer requested it. The condition of the surface of the BB is better than what I normally encounter. I am running short on time to deliver and am wondering if the undercoat/sealer will be enough. I usually apply two coats of primer, sanding between coats before final coat.
8/23/23       #2: Sanding BB before undercoat/sealer? ...
Depends on the quality of the sheet stock you get. I've seen some cheap stuff where the face felt like a corn cob, nice a fuzzy.
8/28/23       #3: Sanding BB before undercoat/sealer? ...
Michael Member
Thank you.
