Subject: Re: Spraying equipment
Spraying equipment
9/9/23
John Roberts Member
Hello,
I am a remodeling contractor who does his own finishing on smaller jobs. I work with my cabinetmaker when using conversion and lacquer finishes. I use my Graco airless when doing oil and latex paints. My question is I’m looking to spay either polyurethane or a spar varnish. Does anyone use an airless handheld unit with quality results? Brand used, tip sizes normally used? Thanks.
John
9/9/23       #2: Spraying equipment ...
Dave Edgerton  Member
Both of those materials spray differently so when you say handheld do you mean a spray gun like a sata? Just need a bit more info to advise.
9/10/23       #3: Spraying equipment ...
Mastercabman
Graco just came out with the ultra quick shot not long ago
It's a little pricey for what it is but might be something to look into
9/17/23       #6: Spraying equipment ...
Jeff Austin
Back in the day, (late 70's early 80's) we always used airless to spray a lacquer on products. They were Graco Presidents that put out alot of gpm's. Lately the only airless pumps I have seen are the electric ones that aren't the best for a furniture type finish. But when air assisted airless came out many started to switch to that because the transfer efficiency was so much better and the final look was so much better. Besides most paint manufacturers are making their products to spray with air assisted airless. Even the HVLP guns now a days have some good results.
