Subject: Re: Primer seems to not want to completely dry
9/11/23
Michael Member
While I just need to finish this project, I thought I might ask where I went wrong.
I have kitchen cab remodel job, not too large, was using BM undercoat primer 032, which is oil based. Great primer. I was on the last of the wall cab doors, made with BB, and ran out. No 032 at the store so went with an Insl-x Prime All AP-1000. Straight on the BB panels, no other primer, sanded to 320. I spray with a Fuji Q5, and dry in a controlled room with 35-40% humidity.
This primer, the Insl-x just will not completely dry. It is not tacky, but has that kind of very light stick to it. It has been drying for 48 hrs. It feels fine in the spray/dry room. But when I take a panel into the shop to sand the primer with 320, it is like it is absorbing moisture. My shop is about 50-55% humidity.
When sanding, it does not have that powdery feel but rolls off thicker and just clogs up my sandpaper.
I have never had this problem before and am blaming the Insl-x primer. I am now content to just burn through sandpaper and get the job out of the door as I am already a week behind, however, I am wondering if there is something else in my workflow that could be causing this.
TYIA for any thoughts.
9/11/23       #2: Primer seems to not want to complet ...
It says on it's technical data sheet; maximum adhesion and hardness may take 3-4 days to develop.
