Subject: Re: Cleaning paint room stainless steel table
9/24/23
Mike  Member
I have a stainless steel table that I use to mix my paints and finishes, most of which are post-catalyzed conversion varnishes. The top of the table is a mess from years of use and spills. Are there any good methods to clean it up and make it look halfway presentable?
9/25/23       #2: Cleaning paint room stainless steel ...
herb johnson
acra strip heated fifty fifty with water........
hands down or let mek sit on it for awhile.
9/25/23       #3: Cleaning paint room stainless steel ...
Chemmy  Member
Use a heavy duty paint stripper, for either, automotive or aeronautics, use, dam the edges of the table so as to stop any run off, pour the stripper on till it covers the depth of the dried coatings by a quarter of an in, put a sheet of 4mil or thicker clear polyethylene plastic over the stripper and leave overnight, remove plastic and use scraper to get under the paint to see if it has dissolved the paint all those the way down to the metal, if so, then remove the clear plastic cover and scrape, repeat if there are stubborn spots here or there.
2nd method, use a belt sander, start with 80 grit, till most is removed, then follow with 120, 150, down to where the table is clean.!! If your top is not flat, you may want to skip both methods or be prepared to apply another sheet of steel over the old one.!!
Either way, I would advise using a polyethylene coated brown craft paper, to mask off your top, ( available in 3' or 4' rolls...so that u never have to do either suggestions in the future,,,,u can also use it on your spray turn tables for the same purpose if you have such.!!
9/25/23       #4: Cleaning paint room stainless steel ...
I'd take the top off and flex it pretty hard. Before buying aeronautic stripper, I'd go to a restaurant supply house and ask to see used restaurant work tables.
9/25/23       #5: Cleaning paint room stainless steel ...
Dave Edgerton  Member
Hot air gun
9/26/23       #6: Cleaning paint room stainless steel ...
Mike  Member
Thanks for the ideas, fellas. I'll give them a try and report back.
