Subject: Re: Home Oven Drying 130504 DESICCANT CARTRIDGE
11/11/23
Michael R
I read on this forum before that the DESICCANT CARTRIDGE can be dried out in the home cooking oven instead of buying a brand new 130504 CAMAIR DESICCANT CARTRIDGE. Before I attempt with my cartridge, can anyone with some experience give me instructions on this before I start this weekend? Or based on your drying home cooking oven experience it's just not worth it.
When will I know when it's dried out?
How many hours or maybe over the weekend?
What temperature is good?
Thank you!
11/11/23       #2: Home Oven Drying 130504 DESICCANT C ...
Leo G
I have no idea if this will work with your cartridge or not. I have desiccant that I use in my safe that I dry in my oven. I use 300ºF and when it changes back to it's original color of orange I know it's dry. Usually a couple 2, 3 hours.
Sounds like one of those things that it can't hurt to try. If it works you know how to do it. If it doesn't you had to buy more anyway.
11/12/23       #3: Home Oven Drying 130504 DESICCANT C ...
Michael R
Thanks, Leo!
11/16/23       #4: Home Oven Drying 130504 DESICCANT C ...
Mitch Suber Member
I’ve been reusing the same desiccant for years. I filter my air into my paint guns through a double canister setup, but mine use a loose fill product, not a cartridge. I forget the temperature I use, but I would opt for a slow steady dry process. The only unpleasant thing that has ever happened is it will sometimes smell, if compressor oil has worked into the desiccant. It’s not that bad a smell, but if I’m using the oven at home I might hear about it. I think last time I just used a toaster oven at my shop.
11/17/23       #5: Home Oven Drying 130504 DESICCANT C ...
Michael R
Thanks, Mitch!
Actually, I had the desiccant cartridge back in the canister in my spray room just the other day after drying it in the oven over the weekend. I did what you mentioned keeping the oven around 225°. Probably about 12 hours of driving time with moving it around every few hours. The green and yellow moisture indicator on the canister is slowly turning to solid green. I believe it is well beyond being dry and it's nice to save some money doing something as easily as putting it in the oven. I think it was the only thing I was ever successfully able to cook well in the oven:)
Thanks for your input!
11/17/23       #6: Home Oven Drying 130504 DESICCANT C ...
Leo G
As long as you keep it below 325ºF you shouldn't have issues. 225ºF is just above boiling so you might think about going to 250ºF. The stove thermostat might not be really accurate. Maybe use an oven thermometer to check the temps vs the setting.
11/17/23       #7: Home Oven Drying 130504 DESICCANT C ...
Michael R
Thank you Leo
You're right I need to get an oven thermostat. When I was heating the cartridge in the oven I could turn it over and massage it quite easily without burning my fingers even though it was quite hot.
By the way, the green and yellow indicator on the canister is almost all green when checking it today.
11/17/23       #8: Home Oven Drying 130504 DESICCANT C ...
Leo G
Well whatever the temp was it looks like it at least gave you more lift out of your cartridge. That's a good thing.
