Subject: Re: Sanding and sanders for primers
12/13/23
Dan
I’ve used many sanders over the years , favoring Mirka over Festool as of late . We seem to burn through the Festool RTS-400 ,but that’s not the problem but what is is the quality of the primer after sanding. We do a lot of hand sanding as well. But as of late we are doing all kinds of gloss finishes and I m not happy with the level sealer or level primer after sanding with sander . We changed the pads used all the correct grits so basically I was wondering what sanders you’re using and what is your primer sanding process. Post cat ML
12/13/23       #2: Sanding and sanders for primers ...
You think it's just a sander problem? No problem with the operators? If you really want perfection in a gloss finish, I feel you have to do some hand long block sanding somewhere in the process. Way too many operators like to use the edge of a disc and they loose all flatness of the parts.
12/13/23       #3: Sanding and sanders for primers ...
What sander are you using for the primer.
Mirka DEOS 383X CV 3"x8" Sheet Sander should be a good choice for larger surfaces.
