Subject: Re: sherwin EA hydroplus
1/24/24
chris
has anybody tried this product? currently using a 2K urethane but would like to switch to a water base product.
can i spray through a kremlin 10-14 or do i need to upgrade?
thanks.
1/25/24       #2: sherwin EA hydroplus ...
herb johnson
always best thing to do is get a tech sheet from the mfg which i did for, i just googled it. you can easily add a superfilter or something simliar brand to accomplish this. all you need to do is swap out the jic to npt to a npt to npt double s.steel nipple then put the existing fitting on the outbound of any filter.
here are the specs and yes i certainly appears the 1014 will do the job per this info from sw
Air Assisted Airless: *
Air Pressure................................... 15-25 psi
Fluid Pressure ...........................400-600 psi
Cap/Tip ..........................................011-.013”
* EA Hydroplus has been tested using the
Sames 15C25 and 15C50 Airmix Pump with
Xcite+ Gun. Best results were found when
using the SuperFilter on the pump.
i would look at ebay for new s. steel filter, the superfilters are might expensive as are the their filter elements..
good luck herb j
2/19/24       #3: sherwin EA hydroplus ...
chris
Thanks Herb.
getting a demo this Thursday.
8/30/24       #4: sherwin EA hydroplus ...
Spk
I am trying this product next week in a demo. I’ve googled it and haven’t seen any reviews, only manufacturer advertisement. I’ll repost after i spray . How was your demo?
9/4/24       #5: sherwin EA hydroplus ...
chris
SPK,
had the demo but did not like the product. It is very thick similar to latex paint.
tried to spray through a hvlp gun with a 2.0 tip but still didn't come out well.
very disappointed with the whole demo. was not about to set up my kremlin 10-14 to try spraying it.
