Subject: Re: Ghosting on Finish
Ghosting on Finish
2/2/24
Scott B
We are spraying ML Campbell Stealth CV in satin finish, white color, material mixed with 5% catalyst, 5% flow 2.
We have what appears to be a ghosting on the finish or halos. It shows up at different angles of light and does not always happen consistently.
Spraying with a kremlin 10-14 pump and .094 tip, 2 bars pump, 1-1.5 bars air to gun, 10"-14" from surface.
Any ideas welcome.
2/2/24       #2: Ghosting on Finish ...
Jr Lee  Member
Website: http://www.leecabinets.com
Scott you should be using 10% catalyst unless you use a different one than I use. I don't know if that will correct the problem but--
Jr
2/2/24       #3: Ghosting on Finish ...
Scott B
JR, in southern Calif. we use the 5% care catalyst.
2/5/24       #4: Ghosting on Finish ...
No primer?
2/5/24       #5: Ghosting on Finish ...
Scott B
Rich C, yes we use MLC Kwik Claw formulated for 275 voc. 5% cataylst, 25% MLC lacquer thinner.
2/8/24       #6: Ghosting on Finish ...
Color Inc Member
Never heard of ghosting. But 5% cat seems like it could be an issue. Would effect dry cure times and may be a cause. Not sure but the issue may go away after it cures out.
I reduce my stealth at 20% to 25% with cat at 10%. Use same kremlin 09 134 tip at 15-20 on the gun and 30ish on the pump.
2/8/24       #7: Ghosting on Finish ...
Dan MInzner
It sounds like catalyst bloom. Be sure to measure your materials carefully. Using a scale is your best option. Always add catalyst PRIOR to thinning.
