Subject: Re: Air Make-Up
Air Make-Up
2/8/24
David Waldmann Member
Website: vermonthardwoods.com
We have an air make-up (AMU) for our finishing room. It's only about 20 years old, but we have had many problems with it over the last few years. They seem to be all related to the control part of the system. We have a company come out to "fix" it, and sometimes it works for several months, and sometimes a day or two. I am fed up with spending $2-3,000 each time they send someone out.
So a two-part question:
1. Does anyone have a good AMU tech/repair person?
2. What AMUs (brands/suppliers) have you had success with?
Side/related question. I assume all AMUs are propane/NG because of the efficiency loss that would result from using fuel oil which would require a heat exchanger? At this point I'd welcome the efficiency loss if I could had a simple burner system.
2/8/24       #2: Air Make-Up ...
Any commercial HVAC guy should be able to fix it. It's simply a big HVAC system in a big box. A good residential tech should be able as well. No matter what kind of liquid fuel or steam is used, they all have a heat exchanger. I even imagine an electric unit doesn't just hang the heating coils in the air. If you really want an upgrade, a ground water heat pump would be a great year round energy saver.
2/9/24       #4: Air Make-Up ...
herb johnson
i would call and ask norris weiner in mass for a recommendation.....rupp, weather rite, top brands titan a little cheaper model. rupp and weather rite have a nationwide service number. out of curiousity what issues' to do you? btw, i never liked auto balance systems,if you have that,? much simpler to have two vfd's one for fan and one for airmake up motor...and a magnehelic gauge. sell switches for monitoring pressure get gummed up by overspray and are problematic. simple controls like vfd's and magnahelics mounted on a control panel much easier to trouble shoot.
good luck herb j
2/9/24       #5: Air Make-Up ...
herb johnson
also, i would contact weather rite or rupp directly to purchase a new unit. sure, industrial finishing eqpt distributors are good but you can buy from one of the mfg reps from w rite or rupp and probably save urself a good deal of money. the distributors buy and sell the unit and most likely have a bigger mark up. not trying to dish iefd, but heck money is money and you are getting the same product.
good luck
herb j
