Subject: Re: 2k polyurethane for cabinets
2/18/24
Andy Kreutter Member
Website: http://allkitchensamazing.com
I want to change our spray finishing operation over to a 2k product. Looking to achieve the best possible finish and production speed for our customers. I plan to set up a computerized component mixing system. I plan to have a common 2nd component that is compatible with everything we spray. We do spray everything on a vertical Rail system. I am looking to have primer, paint, clear sealer and clear top coat set up all the time in the system so we can do everything as fast as possible. We plan to install a automatic cleaning feature to the system. I am concerned about our paint colors yellowing. Some sources claim the 2k finish is about as good as you can get while other claim yellowing over time is a issue. Looking for the best solution in 2k finishing that I can find. At the moment I have been testing 2k from Woodwright . We are trying 2k competitors at the moment. Let me know if you have experience in cabinets and 2k with a setup like I am considering?
2/18/24       #2: 2k polyurethane for cabinets ...
herb johnson
we really like ilva and our wagner industrial 2k mixing system. good tech support on both coating and eqpt. good luck herb j
2/19/24       #3: 2k polyurethane for cabinets ...
2K isn't really a fast drying product from what I've been using. CV dries in 15 sands in 40. 2K dries in 40 sands in 70.
It's a much better finish, but I don't think it's a quicker process.
2/20/24       #4: 2k polyurethane for cabinets ...
Hen Bob
We use the 2K Ilva, great product!
2/20/24       #5: 2k polyurethane for cabinets ...
Are any if you spraying Vertical? We are useing the Guffey rail and hang system. We have a 14' x 24' automotive down draft booth. At the moment we scuff sand and spray in the booth. We re like everyone, short on space!. We are trying to figure out a way to sand outside the booth and extract dust so it is healthy and and less of a mess for the rest of the shop. Looking to implement flow manufacturing to our spray system to get everything done faster and more predictable. We are good at the manufacturing end. We need to improve the finishing and tracking parts do we do not mix jobs up. Looking for any advice from people that have made this drastic transformation to improve life in the finishing area.
2/20/24       #6: 2k polyurethane for cabinets ...
gary
Not to hijack this thread (Andy, you might want to start a new thread) but we have a small dry erase board on each of our Guffey carts with the job info on it to keep parts/jobs organized.
3/8/24       #7: 2k polyurethane for cabinets ...
Jon W Member
100% acrylic 2k's that use aliphatic isocyanate hardeners can be almost entirely non yelowing. Gemini sells a Sirca 2k called 6opu79 (tintable clear) that is as durable as aluminum-oxide-containing coatings while maintaining flexability and hasn't yellowed a bit in 5 years when we tinted it white and sprayed a panel for testing.
