Subject: Re: Confusing questions about finishing
2/21/24
Dany Member
Website: http://www.ankacustom.com
Hey Guys, I have these questions that have always bugged me, I hope some of y'all can shine a light. Thanks in Advance:
1. Can you spray Polyurethane, Polyester over Nitrocellulose lacquer? Also vice versa, and also over urethane-based automotive colors.
2. Can you explain the confusion of what is the difference between Polyurethane, urethane, acrylic polyurethane, polyester, conversion varnish, Nitro cellulose lacquer?
3. How does a coating adhere to a surface? What happens specifically ?
4. Are there coatings that are not compatible with each other or should be avoided using them together?
5. What is the difference between Automotive urethane and wood coatings polyurethane?
6. What are the common reasons for why some finishes never get hard?
7. What is the best type of wood sealer to avoid shrinkage in the future?
8. Do you think finish thickness would have any effect on how the wood vibrates? Or if a thick finish will dampen the wood's vibration?
9. What are the best practices when it comes to applying topcoats?
10. How and why do temperature and humidity affect paint?
11. What are the best practices to avoid future delamination?
12. What is the best grit to sand the bare wood to, for the best sealer adhesion?
13. What is the best grit to sand the bare wood for receiving stain?
14. What is the signal to know when you can spray the next coat and still get burn-in adhesion?
15. What properties does the sealer have that are best for sealing and receiving topcoats, but not for the final coat?
16. For high solids thicker finishes like polyester, what gun setups would you reccomend to avoid orange peel as much as possible?
17. What is the proper time window to apply the top coat so it adheres to the base coat correctly and avoid delamination, or to burn in?
18. How can you know when 2 finishes will have a proper covalent bond?
2/21/24       #2: Confusing questions about finishing ...
Chemmy
I will wait and see what others post (or don't post) before I decide to join in.! There will or should be several answers on most of what you ask.
2/21/24       #3: Confusing questions about finishing ...
gary
Bob Flexner wrote several very good books on wood finishing. Check them out.
2/25/24       #5: Confusing questions about finishing ...
Dave Edgerton  Member
Lots of good questions. Chemmy i suggest you take the lead.
2/25/24       #6: Confusing questions about finishing ...
Too many questions! If someone wants a full education in finishing, I suggest they hire Chemmy
2/26/24       #7: Confusing questions about finishing ...
I will try my best:
No
Vast
Mechanical
Yes
Huge
Unattractive basecoat
N/a
1 foot is too much
Liquid form
No idea
Insurance
40
Redlight, green light
Same
.762
Depends on material
Electron microscope imaging
