Subject: Re: Staining Maple and Blotching
4/7/24
howard
I usually do not use stain. This time clients wants a chest made from solid maple stained. My topcoat is catalyzed lacquer. I know there can be issues with blotching on maple, not as bad as cherry, but what do you do in this case? I was hoping to just getting it sanded to 180 and with that level of sanding any blotching would be minimal. Appreciate your suggestions.
4/7/24       #2: Staining Maple and Blotching ...
I can only tell you my process. I do solvent based. There are two ways to prevent or adjust blotching.
1st method is to use stain base, which is stain without any pigments or dyes. You apply it and watch it absorb. If there are spots that dry out quick apply more to that area until it stops or slows absorption. Wait about 90 minutes for it to dry and stain as normal. It should be much more even, but it's also going to be lighter, so do testing.
2nd way is to stain as normal and wipe it quick to keep it lighter than you need it to be. Use a toner spray coat (the stain formula without the stain base) mixed with a 2:1 finish/thinner mixture. Spray it on over the stained substrate until you get the color you need. Usually you need to wait a few minutes to see the final color so go slow until you find out what you need to do.
In my usual situation I would mix 10oz of catalyzed finish with 5oz of thinner and then add 2 cap fulls of the toner (2/3 oz)
4/8/24       #3: Staining Maple and Blotching ...
Yavuz Member
i learned how to color blotchy wood from this forum years ago article by Paul Synder. Please search and read it before you start your adventure with Maple. i will try to find the link for you or someone who knows where at :)
4/12/24       #4: Staining Maple and Blotching ...
brent
When using a wiping stain on any blotching lumber the wiping process is what pushes more pigment into the grain or figuring. The easiest way to avoid this is to use a toner or spray dye stains. I mostly use transtint dyes. MLC has some premixed dyes too. It does take some practice to avoid overlaps and such. When you use wipe stains and dyes together your work will be at another level.
You probably won't be able to sand enough to get the blotching minimalized. It's the natural figuring of the wood that soaks up more stain. On a side note-that is where the saying "go figure" comes from.
