Subject: Re: Shellac Washcoat
Shellac Washcoat
4/12/24
howard
Website: http://woodcontours.net
I try to avoid staining the furniture I sell, but of course I have a customer that wants a maple chest stained. I am going to spray pre cat lacquer as the topcoat. I don't know if I can spray a really diluted pre cat as a washcoat to control blotching, but to have to spray just for that would be a hassle. That's why I was wondering if a quick brushed on 1 pound cut of dewaxed shellac would work under pre cat? There shouldn't be any issues with contact and I don't think there is an issue with strength of the overall finish. Appreciate your expertise!
4/12/24       #2: Shellac Washcoat ...
https://woodweb.com/cgi-bin/forums/finishing.pl?read=870671
4/14/24       #3: Shellac Washcoat ...
Yavuz Member
Spraying washcoat
https://woodweb.com/knowledge_base/Spraying_a_Washcoat.html
4/19/24       #4: Shellac Washcoat ...
Daniel Shafner  Member
Spray the thinned out precat. You will gain better control of what your washcoat is designed to do by spraying, even though your shellac is at a 1-lb cut. Thin down your precat to a 6% solids mix and lay down a wet coat, anywhere from 3 - 5 wet mils. Scuff lightly with 320 grit and then apply your staincoat. If you want to go one step further, make a toner of your staincoat. If the stain is oil based, add in 2 - 5 ounces of stain to 10 ounces of lacquer thinner, and then strain, and add that colored lacquer thinner 50/50 to your precat topcoat. Spray an overall light coat 3 - 4 wet mils of your toner to the top, especially, and all the main surfaces. This toner will be a nice color tie-in for your project. Then, lightly scuff 320 grit and topcoat accordingly.
5/5/24       #5: Shellac Washcoat ...
dar
try a gel stain, not as blochey
