Subject: Re: Strip or remake
Strip or remake
5/10/24
Nathan Grabowski Member
Well I have had a major stain issue on a set of 70 drawers and door fronts. They are qsawn white oak. Apparently the stain did not get mixed properly as compared to the face frames and end panels. They are finished with Sherwin Williams water white conversion varnish. Am I going to be money ahead to try and strip these or just remake. Everything is raised panel.
5/10/24       #2: Strip or remake ...
gary
Is it possible to tone them to match?
5/10/24       #3: Strip or remake ...
I had considered that also, but with them being inset doors I thought the toned vs not would show up.
5/10/24       #4: Strip or remake ...
gary
Tone the doors to get them close or the face frames and end panels then tone everything to match?
5/10/24       #5: Strip or remake ...
5/10/24       #6: Strip or remake ...
Pete
Im not following how bc its inset, it would show up? You have nothing to loose by trying to tone them. That would be my first choice before stripping. If you do strip, you most likely will have color issues to deal with bc the same stain will probably not match.
7/2/24       #7: Strip or remake ...
trueframe Member
It depends on what you want to achieve. Stripping means starting fresh while remaking could mean improving what's already there
7/24/24       #8: Strip or remake ...
Frank Garrido Member
Website: http://www.cabinethero.com
Sanding the frame of the doors and drawer fronts and resealing these to match the frames can be one option. Varnish is messy to strip. Sanding the frame of the doors can be quicker, and clean, It is possible to achieve the desired tone that will flow with the inset frame of the cabinets. Once this part is achieved the second part will to adjust the color accordingly to match the frame of the door. Color adjusting the panel is more forgiving because it can have a slight difference due to several factors
one the nature of the way it is presented.
The frame of the door and inset frame on cabinets on the other hand must be dead on.
I would at least try this approach if possible. You might surprise yourself, I have used this approach in the past. It will depend If the panels are not too dark already though.
