Subject: Re: Airless sprayer advice for repainting our cabinet shop, very tall exterior
5/13/24
Matt Member
We are a cabinet shop our finish booth crew is going to be tackling the task of repainting the outside of our building spraying DTM acrylic primer and topcoat. I'm going to buy an electric pump for this since these products need 1500 PSI.
First question, since this would not be a constant use product, I think the Graco Magnum X7 would suffice for this. Correct? Our building is approx 120ft x 80ft with 12ft tall walls on the long sides and 17ft peaks on the ends.
Second, I need some ideas on just how long of an extension you can legitimately use on these spray guns. On the backside of our building we have our backdock pit that is sloped below grade, and this is where we put our dumpster and dust collector since we don't need a backdock. I cannot put a scissor lift here because of the dust collector frame, and the sloped pit.
We will need to take advantage of whatever the longest extension we can get here but I am unfamiliar with the technology. I assume I need to look in to getting a pole gun, but can you paint something that high with just a pole gun? How many extensions can you reasonably use to reach a height like that?
We can stand safely on some of the dust collector's framing for some of this thankfully.
5/14/24       #2: Airless sprayer advice for repainti ...
herb johnson
first, thing to consider is the pressure drop thru the long hose and then an extension. i would go for at least a larger size pressure rating towards 3000 psi. as far as hose length start out with at least 25' of 3/8'' id thena qtr by qtr male nippel and end up with a 1/4 id hose.;the a 6' lance or extension with reversible tip.
