Subject: Re: Tips for finding imperfections
3/4/24
MrSpeaker Member
Hey guys I'm still a pretty green finisher. I work in a very busy shop. Just reaching out see see if anyone has any tips and tricks for finding small divits and imperfections in panels that are primed white. My situation is I dont do my own sanding. We have a sanding department. They tend to miss alot of the small stuff. Then my guys dont see it and prime over it sand it and it comed to me for topcoat. It's very frustrating to have to keep stopping once I see it on the first pass lol. So hard for the lads to see the small imperfections with the lights shining down on the white primer. We use black primer for dark paint and they catch a lot more. I was almost thinking of using a neutral primer for lighter colors and just scrap the white primer altogether. We exclusively use Chemcraft CV for all our finishing. Just wonder if you more experienced lads had any tips or input into a situation like this.
3/4/24       #3: Tips for finding imperfections ...
You need to use a low angle light, called a raking light. It will show imperfections easier, casting shadows with a bump or a hole. For small holes I use a Mohawk Fil Stick to fill it in. Rub it on to fill in the imperfection, use a card or razor to scrap it flat and then some sandpaper to remove the glaze of the wax. Workes pretty well.
3/5/24       #4: Tips for finding imperfections ...
I agree with Leo. A flashlight will do. Make sure the flash light is not too bright. You are looking for the shadow, an excessively bright light makes it harder to see.
3/5/24       #5: Tips for finding imperfections ...
MrSpeaker Member
Yep mohawk filsticks and razors are my go to lol. I will look into this raking light or a flashlight. To help the guys out. Maybe a head strap one. They put these led lights above us thinking it would do us a favor but man these thing are so bright. Ha. Ha
3/5/24       #6: Tips for finding imperfections ...
You really need to put it down low, almost touching the part and have the light cast over it. That's why lots of booths have lights on the walls.
3/5/24       #7: Tips for finding imperfections ...
CraigM
Some shops use 3m Guidecoat. I've used it on high gloss jobs, it does a good job of showing imperfections. Link posted below
3m Guidecoat
3/6/24       #8: Tips for finding imperfections ...
MrSpeaker Member
Thanks for that will have to look I to it. :)
3/7/24       #9: Tips for finding imperfections ...
chris
https://sandmanproducts.com/inspection-lighting/
this kind of light will help a lot.
6/5/24       #10: Tips for finding imperfections ...
trueframe Member
When looking for imperfections, carefully inspect the item under good lighting. Taking your time and being thorough can help in finding imperfections.
    • 2Sand
